when I've finalised the hydraulic mechanism
Will this be a hydraulic ram pushing on the under side of the carriage ?. or variable fill counter balance tank(s) using water.
Bs en 81-41 gives you the safety factors you need for a platform lift.@ endecotp ... people
@ freddiemercurystwin ... I didn't come to this forum for sarky condescension - I am not a planning/building regs expert and I hoped I might find some knowledge here beyond Google. Googling turned up nothing on domestic lift regulations; nor any building regs or planning law relating to interior or exterior lifts. The absence of a Google reference does not mean that such regulations do not exist, it could just mean one is just using different terminology in the search. Also, a 2013 reference does not tell you that the rules changed after it was written.
And wisdom has nothing to do with designing simple machines.
@ bernardgreen ... 220kg is the static load and I will come up with the dynamic load and safety margin when I've finalised the hydraulic mechanism.
Are you familiar with LOLER ?
If building a shaft then planning need to know, you will be breaking the fire barriers between floors, and you probably need to ensure that there is a refuge provided in case of Fire, and a rescue window of a given size
I had not heard of LOLER
If you use cables then you will need some sort of braking system to stop the platform crashing to the ground if the cable breaks. Platform lifts are normally lifted by a direct acting ram with anti rupture valves or nut and screw drive.... the cantilevered platform (with hand rail) will be suspended on cables and will roll up and down wall-mounted rails. Appropriate pulleys take the load to a vertical wall-mounted hydraulic ram. Control is by house-mounted switches with safety overrides.
Loler doesn't apply to disabled access platform lifts travelling at less than 0.15m/s for a mechanically driven lift or 0.08 m/s for a hydraulic lift. The machinery directive and bs en 81-41 covers this type of lift.I'm surprised that you had not heard of LOLER, because if you had done any sort of research on lift safety regulation you would have discovered it. It's true that it probably does not apply to you, but still you would have heard of it.
What I think does apply to you is the Lifts Regulations:
http://www.legislation.gov.uk/uksi/2016/1093/contents/made
https://www.gov.uk/guidance/lift-manufacture-and-installation-responsibilities-and-regulations
I've had a quick look and I can't immediately see any exceptions for DIY. It all seems to apply to anyone who "puts into service" a lift.
There does seem to be an exception if it is slower than 0.15 m/s.
