Small particle appearing wood flooring
24 Mar 2006
Surrey
Hi Everyone,
What are these small particles that keep appearing even after I hover them away?
do you mean dirt under the skirting?
I can't really see it. scrape a bit onto some clean paper.
Do you get woodlice?
Any sign of ants outside , they often deposit their litter from their "back door" which could be behind the skirting.
Ok, good idea, I hope no one has hovered it up.
I have not seen any woodlice (assuming I even know what they look like, lets say I don't see any creepy crawlies).
Thanks for the reply foxhole. I will try to check out then get back.
OP,
Why not remove a length of the skirting, & post a pic of whats behind it?
Also why not post a pic showing the outside wall - ground level area?
