Hi, I've got no plumbing expertise, but I'm sure this should be easy. I've uploaded a picture of my problem - we have a toilet, the button lifts the green hook (arrowed in the pics), which lifts the white tube & makes the toilet flush. The problem is that the hole that the green hook goes through, has snapped, so the button doesn't make it flush anymore. It still works fine if you manually lift the white tube up.
There are loads of other holes lower down on the white cylinder, but if I put the hook onto one of those, the tube stays up, and the toilet constantly flushes. What do I need to do to fix it? Is it possible to easily change the white tube? It's from Geberit according to the writing inside, but I can't find this model on the geberit website.
Thanks for any help!
