Yes it says on it fill with rothenberger manometer fluid then the product code.Then you need to use tap water. Not the coloured liquid. the specific gravity of the liquids is different so the results will vary.
You should know this though from your ACS surely?![]()
Remember to include the meniscus![]()
Depends on the range of pressures you want to measure.
One bar pressure using water will need a tube more than32 feet tall , using mercury ( health and safety concerns ) will need a tube 2.5 feet tall
Aye, where do you buy that meniscus, eBay?
I had one taken out of my right knee so if you can ind it, knock yourself out.
This is when I post up this;
Can't beat a general anesthetic. Cracking highs they are..
Feckers kicked me out of hospital after lunch though.
