Nice for the feed back
but that's a mess did he use a trowl ..
Nice for the feed backbut that's a mess did he use a trowl ..
It must have taken him a long time to type in 700 reviews.Well I called another local plumbers who had over 700 good reviews on Check-a-trade
Don't comment on here because their solicitors monitor websites for anything unfavourable and demand that it is removed.
Google "checkatrade complaints"
You may find it interesting.
The solicitor should have pointed out to you any conditions, in the deeds of the property, setting out any responsibilities you have. He may, of course, have just sent you the document, expecting you to read it through and understand all the legal mumbo jumbo, and ask him what it meant.I own the property and it's a leasehold. I do have some paperwork from the purchase but I've only glanced at it and it's quite unclear about who is responsible.
My wife's face usually ends up looking like that on my birthday![]()
can't be bothered to read thread again . aren't you going to need access for future use ( its there for a reason) so sticking it permanently isn't good so try the bolts and make your own gaskets with something like this ;Neoprene Rubber Sheet 200mm x 200mm 3mm Thick - Commercial Quality for Water & Weather Seals, Gasket…,
You need to do that ^^^^
The old seal will scrape off.
Am I right in thinking that you would just do this:
1) remove the outer iron plate
2) place the black rubber sheet behind, and put plate over it so that the rubber is sticking out all around the side
3) screw the plate back on. Then it should be an entire rubber seal around the whole area?
If your wife saw this, she would go Nuts!
Andy
