I found a small leak through the main waste water pipe (not at a join of pipes or on the plastic pipe from the toilet itself but on the underside of the pipe in a small localized area). So I taped it up with masking tape to check where it was. Upon doing so the toilet base started leaking at the back (through a gap in the silicon seal around the base on 1-2mm).
So I removed the tape and put a small pot under the pipe to collect the water. After some time, the pot had water in it from the pipe leak and no water seemed to be leaving via the base of the toilet.
How can these be connected?
I am reluctant to call out a plumber until I understand some of what is happening.
Any help much appreciated.
[/b]
[/b]
