New uPVC Underground Drain Fittings Seeping
Yes, if you joint 2 pieces of pipe together with a socket you have 2 joints, 1facing each way.
I cannot imagine those adjustable bends have a direction of flow, if they did there would be an arrow on them.
My job yesterday was tiny but needed 6 joints:
......and the wrong trap!!
I even showed my plans to the guy at the builder's merchant and he had no objections to the plans
Tozzy,its good to hear you have a knowledgeable and helpful builders merchant,
Would you consider your drainage work a repair or a new drain as some Building Control involvement could be necessary :idea:
The photo by Ian H of his drain job would be considered a repair :!:
Considering my new drainage run is connecting onto existing clay via an adapter, leaving the drainage at the front intact, I would regard the current work I'm doing as a repair.
Sorry Tozzy, but it's notifiable to make sure you've done is right, that's all. A repair would be replacing a piece or two, but you've gone just a little bit past the repair stage.
I'll make sure it's all correct then. So what I've decided to do is take the advice what Hugh already provided and redo the part from the IC and adaptor with the fixed parts he suggested which I bought today. But thing is I couldn't manage to get the 45 degree so I'm wondering whether to keep the adjustable there as is or not.
It was good advice, and I meant to throw in a like for him. Follow what he says if you can, and use you're common sense if you can't.
Certainly will. I've decided to replace the 45 degree also so I'm following his advice to the letter now.
Thanks for the constant feedback by the way. It's been very much appreciated.
Don't be afraid to ask if you're not sure. Drains do an essential job, often in a harsh environment, they get abused, and are usually forgotten about until something is amiss. A bit of extra time taken at this stage will hopefully guarantee you many years of trouble free service.
Bodge and bury and you'll regret it, sorting out the aftermath of a badly installed drainage system is neither cheap nor pleasant, believe me....
Many thanks Hugh. I'll see how I get on. I feel confident regarding the rest of the run where gullies will be installed but I might just need some confirmation nearer the time as to whether anything needs to be altered. I'll be using double socket adjustable bends on those traps to meet the branches simply because I'm happy to use them there and I've already bought them. If you could just just keep a watch on this thread for the time being, I'd deeply appreciate it. It's times like this when you have noone to turn to where you need an expert such as yourself a touch of a button away :)
As long as you continue the thread, it'll flag up to those who have contributed. Take a look at the Bookmark option, and the inbox as well.
If you need to buy more gullies, go for the bottle gullies. Easier to clean out in event of a problem, and only one joint on the outlet needed. ;)
What's wrong with it?
For rainwater it should be a Marley UG44 & UG47. What you've fitted will result in you cutting the plastic grate & the RW shoe is too low. These gullies are not designed for rainwater. You're clearly not a Plumber but a Grubber.
Always fit Marley & follow their design/installation instructions.
At least the OP has used the correct RW gully, that can be easily cleaned out by removing the plastic grate.
Bottle gullies are not designed for RW. You Grubbers shouldn't be laying drains.
