Start Stop Button
9 Feb 2014
Yorkshire
Hi could someone show me or tell me how to wire a start and stop button to a contractor so that it stays on when the on button is pressed and goes off when the stop button is pressed.
What did you want to control?
https://www.google.pt/search?q=star...QsAQIXg&biw=1606&bih=795#imgrc=IJp1UZb2rW5vUM:
Yes.
The start button (normally open) energises the coil which, as well as completing the circuit for the appliance, also completes the coil circuit which keeps the coil energised.
Then the stop button (normally closed) opens and disconnects the supply to the coil which releases the contactor and opens the appliance circuit(s).
Current path for coil continued energising after start button has been pressed
until stop button is pressed.
Also worth remembering
Extra stop buttons are wired in Series
Extra start buttons are wired in Parallel
Though when delving into 400 volt, the coil voltage would determine how its wired.
Although the basic circuit is similar
A 240 volt coil would have the control circuit wired across L and N
A 400 volt coil would have the control circuit wired across Phase and Phase and could even have no Neutral present
