Window restricters
Tried a couple but so far none fit the space available. Will have to buy a few and see what will work.
That is unfortunately, the problem you've got. You know the configuration of you're windows, and it'll be a judgement call on your part as to which ones will fit.
Best of luck
Many of the restricters sit in the slot at the bottom of the frame and need 100mm of space, have slightly less and my hinge is full length of the frame.
