530.3.4 says nothing about any parts of the installation being single-phase or not - that reg applies to installations that have a "single-phase supply". If we are considering that I just have one installation, then I don't really see how one can say that that the supply to that one installation is "single-phase", largely because it isn't!
It may not have a single, single-phase supply.
But with no 3-phase circuits, no 3-phase loads and no 3-phase devices I do not see how it can by any stretch of the imagination be termed a 3-phase installation. But I do see how it can very easily be termed multiple single-phase ones, and I don't feel the need for any gyrations about what the regulations intend. In fact, if you consider the talk of "
≤100A" and "
under the control of ordinary people" I think it far more likely that they intend your house to have 3 single-phase installations, not 1 3-phase one.
Not really. However, as I said, I would suspect that a lot of people (probably including myself) would probably regard everything electrical within a single dwelling as being 'the (one) electrical installation'. In a block of flats, each flat would be a separate single dwelling, in the same way that my house is a single dwelling.
If the landlord were to knock two flats into one, but make no changes to the electrics, you're saying that there would then be 5 installations. So in the new Flat 1, would that be a 2-phase installation?
This has much in common with the discussion on Gatso time and space.
Basically, if you propose a defining rule which does not work, i.e. it does not create a determination free of ambiguities, with no dependencies on any "well it depends" etc, then your rule is a false one, and you have to discard it and find one which does work.
