Fire door linings
28 Mar 2017
Aberdeen
What makes a door lining / casing, a fire lining compared with a non fire lining casing?
Minimum timber density / minimum finished thickness / hardwood linings for 60 minute rating / thicker (can't remember the dimension!) planted stops / some timbers are not rated for FD purposes
So would min 30mm thick qualify together with tuplip or other softwood? Why does it need to be hardwood?
So would min 30mm think qualify together with tuplip or other softwood?
Subject to the lining meeting the door manufactures specification
It doesn't - the lining needs to be able to resist fire for the specified period. Generally softwoods won't meet 60 minute resistance specs.
The fire resistance is met when the lining, door and hardware work as a complete unit.
