Is there such a thing as a triangular hot water cylinder that maximises the available space under the stairs?
I can't find anything on Google so I'm pretty sure there isn't and suspect this may be due to the way they are designed to allow hot water to rise to the top.
My existing tank is 180 litres and uses the full height under stairs but there is space behind it as the stairs go down to the ground floor. Relocating a new tank and pipes will require an expensive wooden floor to be ripped up so I'm trying to avoid this if possible.
Thanks.
Thanks.
