Hello, I moved into a property where there is a very rough supply to an unattached garage.
Basically its 1x2.5mm and 1x 1.5mm cable running about 2.5m off the ground from the kitchen to the garage - they are then tie wrapped together.
Its not good - the amount of times I have nearly taken it out with a piece of wood, obviously I need this doing correctly, I just need to know the correct method so me and the electrician are on the same page.
Should the cable run underground under the flagstones? if so should it be armoured - or can I use some form of conduit?
I dont see any method of above ground due to the circumstances of the building.
