Nevertheless, that is how most customers think.Faulse economy. Installing all CUs with RCBO is not a great amount of money.
With all RCBOs the compromise is vastly reduced. Then with DP RCBOs the compromise is vastly reduced again. RCBOs are not a great expense, for what they offer. It is a no-brainer.Electrical installations are a compromise.
Safety is last on the list after economy.Nevertheless, that is how most customers think.
Yet Bernard has given an example where it would be beneficial not to do it.With all RCBOs the compromise is vastly reduced. Then with DP RCBOs the compromise is vastly reduced again. RCBOs are not a great expense, for what they offer. It is a no-brainer.
If your young daughter was electrocuted because someone wanted to save a few quid, you might think differently.How many millions of RCDs have been installed?
How many fewer casualties are there now than before?
There is a greater chance of being protected via an RCD or RCBO than not having them. Pretty obvious really.What if your young daughter was electrocuted because somebody thought an RCD would protect her?
His point is an RCD is not the one and only solution for protection against electric shocks. They MAY stop you getting a fatal/harmful shock, but they also may not. A well designed, well installed and maintained installation is far more important than an RCD.There is a greater chance of being protected via an RCD or RCBO than not having them. Pretty obvious really.
We've been through this umpteen times before.There is a greater chance of being protected via an RCD or RCBO than not having them. Pretty obvious really.
I presume you mean "all-RCBO", in which case I agree with you.The problem with all-RCD boards is that you don't know if a trip was caused by overcurrent or earth leakage (or even spikes on the supply).
Ultimate what? Surely a massive Henley block with swa to every light/socket and individual rcd and fuse would be the ultimate?Thanks Bernard. A double pole RCBO in all slots on a CU is the ultimate then.
You presumably are referring to the situation in which a substantial potential difference arises been two parts of a human body, in which case I agree with you. One might add a comment about the commonly-held misconception that an RCD/RCBO will limit the shock current to 30mA or whatever, which obviously is not the case - such as device will, if it operates, limit the duration of the shock, but not the amount of current flowing through the person during that brief period of time.An RCBO, or other RCD, will not prevent you getting a shock. It might prevent a shock from being fatal.
