accenta g4, attaching relay, getting confused....
13 Jun 2016
Hi purchased 1 port version of this....
http://www.ebay.co.uk/itm/12V-Relay...&sd=282576987893&_trksid=p2047675.c100623.m-1
connected output side to lights which I want to go on when the alarm goes off
input side, the three pins.....
1) connected "+" and "-" pins to a 12 volt power supply
2) connected "s" piin to the accenta g4's "remote signalling input" "INT" connection J3 (see p15 https://www.security.honeywell.com/uk/documents/IE1-0040-Rev1-engineer.pdf)
But when alarm goes off, I assumed that as "INT" went from 13V to 0V, it would then click the relay and so light up the outside lights (and back off once alarm was reset and "INT" goes back to 13V)....
but nothing :(
Any ideas please?
Harry
How are you triggering the 230v light ?
Mite be better or with a single pole 12volt dc relay and base ?
If you connect relay to bell trigger when the alarm goes off the lights will come on for the duration of the bell timer.
This depends on how you connect the relay to the light or lights unit ?
i have "sliced" the positive cable going to a normal 4 gang 13 amp extension (into the relay), the lights are attached into the extension
its an active low relay... i think that means relay will come on once voltage drops to zero on connection... the g4 alarm panel has that conenctor (on J3)
Whats the coil resistance of the relay on your unit
You panel output mite not be triggering the relay ?
Have you got a multimeter to check output when the alarm is triggered?
i think this it it..... http://www.satistronics.com/mini-12v-dc-power-relay-srd12vdcslc-songle_p2160.html
from alarm manual..... " OUTPUTS (J3): These outputs are programmed as active low output. They are held at 13V and fall to 0V
when active, it can source or sink 10mA"
so the 10mA "sink" - whatever that means :) - compatible with the relay please?
On some alarm control panels the outputs can not drive the relay
The easiest way is to connect a basic single pole 12v d/c relay to bell output and you can check the relay output with your multimeter
Ok thanks will purchase one and try that, although I assumed this relay got its power from the separate power supply ive attached to its +ve -ve terminals.
When alarm goes off the INT connection on the panel (connected to the "s" input pin next to the +ve -ve input pins on the realy) goes from 13v to 0V (I've confirmed that happens)
Connect relay coil to 12 postive on bell trigger and sw - bell trigger to relay coil
You then have the relay com,nc,no to connect the light unit.
How are you connecting the 230v light ?
A 12v Octal relay & its base is what you want, so easy to use. I must have installed hundreds over the years when installing alarms.
