Numbering data mods - is there a kit?
22 Jan 2012
UK
I have flood wired the whole house with data cabling, and had Triax cat6 mods terminated on each one.
They are currently all unlabelled. Is there a kit you can buy to sticky label them They don't have a clear plastic cover), 1 - 24 ? I have a Dymo labeller, but don't think it will take a suitable sized tape.
Thanks!
Tim
I've always used a dymo labeller and stuck on the faceplate e.g. 10/11 for a double if the module has no window
They do have space for a label, like this:
But they don't have clear cover to insert the paper. So I was hoping there was some kind of label kit I could stick in there, that fitted neatly.
Your idea is fine for a commercial environment, but I'd like it to be a little more discrete for my living room I think :)
Phatboy,
I use the Dymo type printer a lot, but have found that they can fade, and as you suggest do not fit into the little square box perfectly, or can only get a limited amount of text/info into the box.
When Dymo is not suitable, I use computer/Word to make squares of text that perfectly fit the area I need, and print onto self adhesive labels, which I then cut to size.
The laser print is water proof, does not fade, not heat sensitive and fits perfectly (when cut to size). But being paper not abrasion proof
Would this work for you?
https://www.amazon.co.uk/dp/B000I5VXWG?aaxitk=yIT55LwonTt1kkQfVp39VQ
SFK
