Best plug and screw combination for shower door?
7 Feb 2012
So the shower door has broken and am looking to fit another one above the bath. It's a tiled bathroom so I know I need a tile drill bit but behind the tile there is plasterboard wall.
So my question is that plug and screw would be best?
Now I have drilled into plasterboard before and used some plugs and screws but these have been light items and don't think they would work for a heavy shower door.
Any advice folks? Thanks
Where it was already fixed, was there any timber pattress or baton? Stud? Is it definitely just PB?
I will try removing the old fixing and have a look about to see.. I suspect it's just plasterboard though. I was looking at blue rawl plugs on screwfix which look pretty sturdy and it says can be used on hollow and plasterboard walls.. what's your thoughts?
Anything baring weight will have to be fairly robust without any backing. The rawl plugs generally speaking won't carry any significant load.
This video might help you a bit more.
If the surface is tiled then it significantly improves wall strength , general purpose plugs should be all that’s required.
It's not the strength of the wall that I'm putting into question but the fixing itself. General purpose plugs are great for "general purpose" items. The further away from the wall the load goes the greater the force outward and downward is applied.
It wouldn't be on the wall but the fixing itself; there's every possibility it would just get pulled out.
I run the silicon up the middle of the profile and seal up on the outside once attached. If drilling through tiles 5.5mm drill bit without hammer action will get you through the tile (hopefully depending on tile material) and use a red wall plug. Before attaching silicon middle of profile then screw to wall if this makes sense
Regards david
