After lots of searching online for bathroom shelves we couldnt find any that were suitable and so I decided to make these:
Our main problem was the space we had available for the shelves which is quite narrow.
I purchased some timber and got to work.
The shelf you can see at the bottom is held is resting on some inch by inch cuts. These are secured into the uprights and rest or 'hang' on the skirting boards. All good so far. The actual shelf is loose as it were.
My main dilemma is how I'm going to secure the remaining four shelves. They reduce in depth the higher they are on the ladder.
I'm thinking two screws into each side along with some PVA. The shelves when built are quite heavy (birchwood ply shelf with spruce sides). Would this be a secure enough method of fixing them? If I get them flush to the wall this should stop (or limit) any downward movement at the rear of the shelf. What do you think?
Thanks for any tips you can give. I'm not tackling this now until the weekend.
Cheers
David
Cheers
David
