Shower keeps going cold
I dont have to phone them up , I work on their stuff on a daily basis, I am not the one hoping that someone will tell me that using leak sealer is a good idea, you have not given any facts at all, Worcester do not advise the use of any leak sealer, maybe you called Fernox, of course they would recommend the use of it
You don't want to phone them up as you know what they will say lol
just keep asking and someone will tell you that it is a good idea then you have the answer you wanted
When was the system inspected for possible water leaks ?,they are easy to find.
If you are going to have a disagreement with me Ian at least get your facts right instead of arguing with me with no facts.
Not that I have to justify however on this occasion I will.
https://www.worcester-bosch.co.uk/support/literature/download/6720818079
"▶ In cases where all attempts to find a micro leak have failed, Worcester, Bosch Group supports the use of Fernox F4 leak sealer."
So there are my facts where are your's Ian?
. I just don't want to have spend a fortune on a plumber for him not to even resolve the issue.
A gas service technician would have sorted it out at this very early stage.
another problem is the boiler keeps on loosing pressure as it seems almost every 2 months I need to top it up
Having to top up won't help with corrosion in your system and can speed up the blocking up of your heat exchanger
its got a leak somewhere.
Date gap of 2 years and boiler being used with known defects (n)
Ok so I am still having this problem I noticed the boiler was losing pressure, so paid a plumber to come around and put some fernox F4 leaksealer and some Fernox F1 protector.
Worcester advice,WARNING: Sealing agents ▶ Normally the addition of sealing agents to the system water is not permitted as this can cause problems with deposits left in the heat exchanger. ▶ In cases where all attempts to find a micro leak have failed, Worcester, Bosch Group supports the use of Fernox F4 leak sealer.
This is a new install it should be free of water leaks.
There has not been any attempts to correct the pressure problem.
No mention that the boiler has been serviced since install.
So relying on Worcester advice is flawed.
Incorrect I have 3 Gas Safe Engineers unable to fix. Ignorance is bliss I guess?
And your point being?
(So I have followed their procedure and your point being?)
Was I suppose to keep paying an opinionated plumber £80 an hour not to fix the root cause?)
This is a new install it should be free of water leaks. (It is free of leaks now as I have used leak sealer!)
There has not been any attempts to correct the pressure problem. (Incorrect a micro leak was fixed taking down a stud wall)
No mention that the boiler has been serviced since install. (Incorrect it has been service every year by a Gas Safe Engineer)
So relying on Worcester advice is flawed.[/QUOTE] (That's your opinion which is subjective )
And you wonder why Gas Engineers get a bad rep they charge £80 an hour and talk the talk yet don't walk the walk.
Well I am not getting any useful advice from you guys so I will take my chances with Worchester.
PS, I have unsubscribed from this form.
