Anything cheap will be pretty poor performance wise, I always use a good fan connected to pir in ceiling which also has an adjustable timer in it. Fan should run anytime the room is occupied not just for showers/ baths.
Why?Fan should run anytime the room is occupied not just for showers/ baths.
Earlier today we went shopping, and bought things which we store in the bathroom (soap, toothpaste, shampoo).Anything cheap will be pretty poor performance wise, I always use a good fan connected to pir in ceiling which also has an adjustable timer in it. Fan should run anytime the room is occupied not just for showers/ baths.
I do mainly have LEDs now - as the CFLs die I put in LEDs. But still - it would better if they weren't leaving lights on.Get LEDs, and stop worrying about them being left on.
If only it was that simple. Eldest has ADHD - I have to pick my battles and lower expectations- getting them to remember to do their coursework or have a battle about leaving lights on...Train your children properly. I was never allowed to leave lights on.
And I'm also curious about the reasoning behind this statement ..... Fan should run anytime the room is occupied not just for showers/ baths.
And I'm also curious about the reasoning behind this statement ....Fan should run anytime the room is occupied not just for showers/ baths.
EFLI (probably) and I (certainly) insist that you put forward a cogent explanation
To encourage good ventilation of a small area and discourage condensation.Why?
Seems like you were wrong again.Foxhole has been back to the site every day since he wrote that, and posted 25 times in other topics.
He clearly has no intention of even trying to justify what he wrote.
I don't see that he can have any reasonable grounds for complaint if we take his silence as confirmation that he knows it was complete rubbish.
I presume you meant when having a bath/shower or when making smells but cleaning teeth or having a wee does not need ventilation nor encourage condensation.To encourage good ventilation of a small area and discourage condensation.
Not so far. At the time I wrote what I did you had not posted here again.Seems like you were wrong again.
Condensation occurs when there is insufficient air movement.I presume you meant when having a bath/shower or when making smells but cleaning teeth or having a wee does not need ventilation nor encourage condensation.
I personally find the noise of a fan extremely irritating and will not have one. There are no problems as a consequence.
Condensation (slight misting of the tiles and mirrors) as a natural occurrence when having a bath is not a problem and should disappear in a few minutes anyway. If it does not, then there are more fundamental problems with the premises. A fan might help or it might not but one should not actually be needed.
If, rather than normal condensation, you mean condensation which does not go away or damp leading to mould, then this, again, is an indication of other problems such as too humid premises or leaks.
Obviously, dealing with smells or not is a personal circumstance and decision.
Anyway, whichever it is, having a fan on is not compulsory.
Did not reply to banal sheds as I am completely unable to justify why a fan should need to go on when someone goes into the bathroom to put supplies away, and therefore "Fan should run anytime the room is occupied not just for showers/ baths" was total nonsense, but I think I can bluster and wriggle my way out of admitting that, and out of other people realising it.
Not so far.Seems like you were wrong again.
New I could rely on Banal sheds another banal reply.Not so far.
