I need to run some lights from a plug socket, am pretty sure this is right but just confirm is the following correct?
Take a cable from the socket into a FCU like this https://www.screwfix.com/p/mk-13a-dp-switched-fused-connection-unit-with-neon-white/58085
Then replace the 13A fuse with a 3A
Run the lights from the FCU, wasnt going to bother with a switch, was just going to use the switch on the FCU to turn lights on/off?
Many thanks
Many thanks
