I have replaced my all plastic light switch with a LED Dimmer switch which has a metal face plate. I know this needs to be earthed but I was just checking to see if this is the correct way to earth the switch as there is no earthing point in the switch back box as it is plastic. I have made my own earth wire up and connected this from the earth terminal on the back of the switch plate and connected this to the terminal block in the light switch housing. This terminal block already has two earth wires connected to it - one from the loop in and one from the loop out i guess? Anyway a picture tells a thousand words i guess.....
I don't know how you inserted your picture, but it is incompatible with our forum.
I have removed it (and from the Quote posts)
Try copy and paste into your post
Mod
Mod
