Leaking Potterton Promax HE
14 Dec 2008
Stirlingshire
Hi Guys,
I've had a leaking boiler for a while, but could never see anything damp on the boiler itself, just a puddle on the kitchen worktop after the boiler hadn't been in use for a while.
I think it must be getting worse now, as there is a small, continuous leak quite regular now. I presume it must be an O-Ring which has failed, but what's the best way to identify it before I strip it down? As I need to guarantee to fix it, as I have a small baby who needs to keep warm.
The leak is on what looks like a quick release type fitting directly after the Flow Outlet
So really my main questions and concern is:
- Best way to identify the O-Ring before removal
- Best way to drain down the system - the boiler heat hot water in an unvented tank, and also does the central heating, so this flow pipe is used for both tasks. Is there somewhere 'special' I need to drain things down completely? I presume refilling would just be at the normal filling loop in the airing cupboard (where the unvented tank is situated too).
Thanks a lot
Ryan
Hopefully Pics are here:
If I was you I would go for a baxi fixed price repair, I wouldnt recommend that job for a DIY repair
Thanks for the replies guys, I will take your advice.
My wife reminded me (luckily) that we do have boiler cover. I found the paper work, and it is from D&G, but it was via Potterton/Baxi. Do they repair that side of the boiler - as that is more plumbing isn't it?
Cheers
is it boiler care , if so then yes . if just plumbing then no
