If it looks that way to you then your seeing is faulty.It looks as if you may have done ....
How about the fact that they do?What aspect of "seem" and "seemingly" do you think indicates certainty?
Yes.John said "it would seem". Does that denote certainty?
]...but 522.6.204 allows that cable while only calling for an earthed metal covering. It does not mention screen.
A difficulty not helped (again) by sloppy language in the Regulations.
What I agree with is that these terms are not properly defined or consistently used in BS 7671.Do you therefore agree a covering is a sheath - and vice versa?
And as we can see, nowhere does BS 8436 say that it has one of those.It may be unsuitable underground for different reasons but 522.8.10 only calls for an earthed metal sheath.
I have already referred to sloppy language in the Regulations, and how unhelpful it is, so I don't think there is any point in trying to analyse it. These terms are not properly defined or consistently used in BS 7671, so you're not going to be able to use them to arrive at any firm conclusions.Is a screen also not a covering and so the cable should not be suitable for burying in walls?
That question makes no sense - armour and sheath are two different things, and a cable does not have to have both.Is the armour (of swa) not a sheath and so not suitable for underground?
This is how IDH describe their Guardian cable:
- Plain annealed stranded copper conductor to BS6360
- XLPE insulation to BS6889
- Aluminium screen tube, applies longitudinally.
Try looking in a Dictionary rather than a ThesaurusHow about the fact that they do?
I trust you aren't arguing that a cable for which the standard does not say it has a metal sheath but does say it has a plastic sheath can be considered to officially have a metal sheath?I trust you aren't arguing that a cable can only have a single "sheath" ?
Try explaining why a Thesaurus must be wrong, or ignored.Try looking in a Dictionary rather than a Thesaurus![]()
You may not take a term defined by a standard, give it a different meaning, and then claim that the standard says that the {whatever} has that thing.No, I'm arguing that a cable that has something which meets the dictionary definition of "a sheath", and where that "sheath" is metallic, has something which is a "metallic sheath" regardless of what the manufacturer or standards call it.
I'm arguing that the definition of the construction of a cable to BS 8436 does not give it a metal sheath.So are you arguing that aluminium is not metallic ?
Are you arguing that a "tube" enclosing the cores does not meet the definition of "sheath" ?
I can point out that in the definition of how a cable to BS 8436 shall be constructed, it is not given a metal sheath.Because unless you argue that one of those is incorrect, then it is rather hard to see how you can argue that in the case in question, the cable does not have "a" metallic sheath.
There is no sheath inside it.It also has an XLPE sheath over the top of that, but that doesn't alter the nature of the sheath inside it.
I'll add you to the list of people whose only concern seems to be to argue themselves out of accepting that there is clearly insufficient clarity about the term for any claim that there is to be valid.Unless you have found some official definition of sheath that differs from what everyone (except, it would seem*, you) accepts as being a "sheath". If you have, then post a link and we can all stand corrected - but until you find and post such a definition, then we have to assume that you are being belligerent in your usual manner of having your own definitions and trying to claim that the rest of the world is wrong.
* Yes, using the dictionary definitions I recently posted showing it's use as "would appear"![]()
Yes.
Therefore all we need to consider is covering and sheath.What I agree with is that these terms are not properly defined or consistently used in BS 7671.
They might be. Are they?What I agree with is the idea that they might be defined in other standards.
Does it have to define covering for us to know that the screen covers and as such may even be a sheath.What I agree with is that no matter what usage you point to in BS 7671, BS 8436 clearly does not define the screen in those cables as the sheath, and clearly does not define the sheath as that screen, or covering over the cores.
We have not conclude that. We are discussing the possibility with you.What I agree with is that there is nowhere near enough clarity for you and John to be justified in your conclusion about what is suitable for direct burying.
Surely a lack of clarity increases the possibility.What I agree with is that you are still trying to argue yourself out of accepting that there is nowhere near enough clarity.
Can we not therefore rely on standard English definitions.I have already referred to sloppy language in the Regulations, and how unhelpful it is, so I don't think there is any point in trying to analyse it. These terms are not properly defined or consistently used in BS 7671, so you're not going to be able to use them to arrive at any firm conclusions.
It does not, but to be buried in the ground a cable may just have a metal sheath.That question makes no sense - armour and sheath are two different things, and a cable does not have to have both.
Accepted. Sorry, I had forgotten that in all the discussion.[/QUOTE]522.8.10 ... a cable buried in the ground shall incorporate an earthed armour or ...
Indeed.Try looking in a Dictionary rather than a ThesaurusVERB 1 Give the impression of being something or having a particular quality. And Collins seem to agree as well - to appear to the mind ..., to give the impression ...
How about "522.8.10 only seems to indicate that that would be OK, there is no certainty that it actually is"?As far as regulations are concerned, I don't think one has to look any further than 522.8.10. That seems to indicate very clearly that any cable with an earthed metal sheath may be directly buried, provided only that that sheath was "suitable for use as a protective conductor" (does that just mean adequate CSA, or what, I wonder?). [other regs obviously require that the cable be suitable for the environment concerned, but without saying anything specific].
However, I still wonder what responses somewhat would get if they came to this forum and said that the wanted to directly bury something other than SWA!
Ah - the Humpty Dumpty approach. Jolly good.Furthermore, I don't really care what definitions can be found in dictionaries or any thesaurus.
I shall remember that last part, the next time you tell me that no matter what I think about the correct definition of a word (e.g. electrocution), dictionaries reflect reality, they do not prescribe.When I add the word "seem" or "seemingly" into a sentence (let alone three times into the same sentence), I do so deliberately in order to indicate a lack of certainty. Virtually everyone will understand that such is my meaning/intention, and most of them will use the words in the same way for the same purpose themselves. If a dictionary or thesaurus indicates otherwise, I would say that it is the dictionary/thesaurus which is 'wrong' in terms of how our language is used.
You seem to be wanting it both ways.No it doesn't. It specifically states what is required.
You seem to be scraping the barrel.
You didn't actually mean it only has the appearance of being all right but you are uncertain?Seems alright, assuming all done correctly.
Good job I got involved - you and John have been discussing this but you mean different things by 'seem/seemingly/etc'Agreed.As far as regulations are concerned, I don't think one has to look any further than 522.8.10. That seems to indicate very clearly that any cable with an earthed metal sheath may be directly buried,
