Hi all
I'm planning an ensuite and as the existing bathroom is in the next room, I was planning to run the hot and cold pipes up inside the wall and through the loft above the ensuite.
I can then put t-joints in along the horizontal pipes in the loft, and drop down vertically at the appropriate points to feed the wc, basin and electric shower.
Other than ensuring the pipes are protected against freezing, would there be any issues with this?
There is a combi boiler on the same floor as the bathrooms, so I'm assuming it will be capable of pumping water up to the loft, as it is only the same as it having to pump water upstairs if it was downstairs in say, the kitchen. Cold water should be able to get up there as there would have been a tank in the loft at some point.
Doing it this way has one very big advantage in that I can do it myself with plastic, all joints in the loft would be accessible, but I would use copper for the vertical drops, with the ends bent using a pipe bender to exit the walls, so there would be no inaccessible joints in the wall.
Do I need to consider anything else?
thanks in advance
Jamie
thanks in advance
Jamie
