Afternoon all,
Just after a quick sanity check on what I am proposing before I start. my landing and stairwell is L shaped and I currently have one ceiling rose hung on the right angle of the L. There are switches top and bottom and it is wired up using the attached method. I am want to replace the ceiling rose with a double insulated spot light, add an extra spotlight on the landing end of the L and then a new ceiling rose with chandelier at the other end of the L in the stairwell.
My plan is to replace the existing rose with a junction box in the loft and terminate switch and lighting ring in the junction box. Where the diagram shows "to lamp holder" i will run twin and earth that to a second box and then wire each light fitting to that box.
In theory I could run all the cables from the one junction box but there would be too many cables terminating in the one box.
Hope this makes sense?
