I have 2 separate lights in my kitchen and i am replacing the ceiling and installing 10 down lighters (mains voltage) can i connect them to the existing rose / junction box, as they all need separate connections can I run them all to one junction box ?
I would replace the rose with a junction box, making sure it is accessible in the future, and run a twin and earth feed from it to one light, then to the next etc... using small 4T jb's which are 59mm dia or terminal blocks enclosed in whats known as a choc box. Bear in mind that selv (12V) connections need to be enclosed, too.
Each light allready has a terminal (junc' box) so I can just connect them all together then and a final connection to the rose (junc' box).
I assume I just seal off the earth in the rose as the lights have no earth connection.
Thanks all for your help.
Yes - so every light fitting will have two 1.5mm twin & earth cables attached, with the exception of the last one which will only have one.
I'd snip off the earth (if not required) at each light fitting and tape up the end or use 2 core flex.
Keep the earthing conductors and connect them up, lets keep the continuity people.......I know the lights are class 2, but one never knows the future......
