- Joined
- 4 Aug 2017
- Messages
- 73
- Reaction score
- 1
- Country
Hi all,
We're replacing our bathroom and have just removed a wall mounted mirror cabinet which had a couple if built in lights (incandescent) and a shaver plug. We're replacing this with a similar (but much more modern!) one that has LED lights and a shaver plug. The cabinet says it requires a 240v mains supply.
The old cabinet's lights and shaver plug were supplied by the lighting circuit, which I thought was less than ok particularly because of the shaver plug (though I'm no sparky). So my thoughts were to try and find a proper mains supply for the new one i.e. run it off the sockets circuit.
Looking at what's nearby, we've got 3 options without major upheaval:
1. If it's actually ok to run the cabinet off the lights circuit, that would be easy as we could do a like for like swap. However with the new one specifying "240v Mains Supply Required" I'm not sure this would be suitable?
2. We've just removed an electric shower from the bathroom which is being replaced by a boiler-supplied mixer, so we have the old shower mains cable available to use. The cable is obviously much fatter, but could we realistically use it to supply the mirror cabinet? Obviously it wouldn't be drawing nearly as much current but my only thought was if the rating of that circuit at the RCD was too high for it to trip safely if there was an issue with the appliance / cabling?
3. There's a socket on the landing, in a wall shared with the bathroom where we plan to hang the cabinet. I thought we could spur off this, but it appears to already be a spur (only 1 cable going to it). Actually all the upstairs sockets I've checked so far have only 1 cable, maybe indicating that the upstairs sockets are all spurs off the downstairs ring, as I've read is quite common in houses built around the time of ours (70s). I will need to check the downstairs sockest to verify this though.
If that is the case, is spurring off that socket a no-no?
Thanks all.
Thanks all.
