You have hereby declared yourself to be a proponent of dishonesty and vice.You can easily buy BT branded NTE sockets - as long as you don't mess up, nobody will ever know.
when a line is "doing nothing" it as at 50v dc when it rings it jumps up to, i dont know what
A helpful guide on how to do it when photos would help.
I don't do sockets.
For the British Post Office (BPO) and the Australian Post Office (APO) the voltage on a telephone line (from the exchange via two 200 Ohm windings on a relay) was nominally 52 V DC - with the Negative "Earthed" at the exchange.The ringing is AC and used to be 80v I think. You got a hell of a belt if you shorted it out with your fingers when working on it!
Cars are different, because there is minimal connection of either side of the electrical system to true earth, hence no significant scope for leakages to earth (e.g. through moisture), so it doesn't make much difference what side of the electrical system is connected to the vehicle's metalwork. In other situations (e.g. telephone systems) where one side of the supply is connected to true earth and the prospect of such leakages does exist, electrolytic/galvanic corrosion will major on the 'anode' - hence a better situation if the non-earthed conductor is negative relative to earth.Yeah, I thought so, but I could be wrong.
My appologies.Battery Positive is Earthed
Having a negative potential on cables relative to earth reduces the amount of corrosion of conductors.
AIUI the ringing signal is also superimposed on the DC, which would make the peak voltage much higher than you'd expectThe Ringing AC Voltage was/is nominally 75 V at 17 2/3 Hz
However, this AC Voltage is deliberately NOT sinusoidal but is much "peakier" in waveform, so the "Peak" voltage is much higher than the 106 V peak to be expected from a sinusoidal 75 V AC waveform.
