I want to make upto 10cm in diameter in holes. Only need for wood.
What drill bit should I be searching for?
The ones I find are labelled for electricians + quite expensive.
I would love a clean cut hole...
But also is there some sort of rubber ring that I can put over to cover?
Most the holes will be for tables and making holes so I can feed wire through
