    Dismiss Notice
What drill bit do I need for making big holes?
Discussion in 'Wood / Woodwork / Carpentry' started by OM2, 31 Mar 2018.
  1. OM2
    OM2
    18 Jan 2007
    638
    Thanks Received:
    Country:
    I want to make upto 10cm in diameter in holes. Only need for wood.
    What drill bit should I be searching for?
    The ones I find are labelled for electricians + quite expensive.
    I would love a clean cut hole...
    But also is there some sort of rubber ring that I can put over to cover?
    Most the holes will be for tables and making holes so I can feed wire through
  2. Sponsored Links
  3. Keithmac
    Keithmac
    10 Oct 2017
    1,435
    Thanks Received:
    231
    Country:
    Google Holesaw..
  4. Notch7
    Notch7
    15 Sep 2017
    17,756
    Thanks Received:
    1,245
    Sussex
    Country:
    big wire then!
  5. TicTac
    TicTac
    21 Feb 2018
    391
    Thanks Received:
    68
    Country:
    You can get holesaws that are designed ti make access holes in floors etc, and you can then buy the covers to drop in place, but I'm not sure if this is exactly what you're after.
  6. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,187
    Thanks Received:
    489
    Country:
  7. KenGMac
    KenGMac
    24 Aug 2010
    2,853
    Thanks Received:
    496
    Ayrshire
    Country:
    You could consider drilling smaller holes, each hole for say live feeds,, the other for Comms cabling and TV Cabling Etc makes for locating a suitable drill and insert cover easier?
    Just a consideration, after all a 100 mm Dia. hole is a beast with a load of break out problems with the edges?
  8. magicmushroom666
    magicmushroom666
    11 Jan 2010
    247
    Thanks Received:
    40
    Essex
    Country:
  9. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,187
    Thanks Received:
    489
    Country:
  10. Sponsored Links
  11. JobAndKnock
    JobAndKnock
    30 Sep 2011
    4,130
    Thanks Received:
    846
    Lancashire
    Country:
    You need to drill from one side first until the pilot bit breaks through, then finish drilling from the other side. Much better finish
    The torque reaction on a 100mm holesaw calls for lower speed and extra care, as well as possibly a long side handle on the drill to avoid injury in the event of a "stick" (I use a Makita DHP480 cordless combi with a long side handle). Not advisable to use low power cordless drills unless you really want to burn the batteries out (by cooking them), I'd say. A drill press is really a better option if at all possible
  12. OM2
    OM2
    18 Jan 2007
    638
    Thanks Received:
    Country:
    thanks for the replies guys.
    10cm? ok... maybe too big.
    @JobAndKnock now you've got me worried!
    i've got mango wood tables - they weigh an absolute ton.
    i didn't think it would be a problem?
    i dont want to go and buy a makita just for this!
    i've got a bosch cordless drill - but if u say it's a challeging job... i don't want to put it to the test!
    drill press - i could buy a drill clamp and use that?
    @Tigercubrider letterbox looks great. i'll consider. but for the first desk... i need a hole.
    EDIT just searched for 'desk hole for sockets'
    bingo
    i think the standard size is 80mm.
    they're called Desk Table Grommet.
    £1.50 delivered - crazy - the item MUST be more than 2.5cm = packet in Royal Mail.
  13. Nozzle
    Nozzle
    23 Dec 2012
    2,078
    Thanks Received:
    265
    Suffolk
    Country:
    If you want to produce quality holes in nice wood - don't use a [hole] saw... Use a Forstner bit (using backing timber to avoid break-out) or a router (with a collar & template)
    Nozzle
    • Thanks Thanks x 1
    • Like Like x 1
  14. OM2
    OM2
    18 Jan 2007
    638
    Thanks Received:
    Country:
    @Nozzle thanks for the advice. Sounds good.
    Backing timber... say if I'm drilling through... you are saying put a block of wood underneath?
    Router? Can you show me what you mean with a pic or video?
  15. JobAndKnock
    JobAndKnock
    30 Sep 2011
    4,130
    Thanks Received:
    846
    Lancashire
    Country:
    You finally said 80mm which is a lot easier to deal with - at 100mm and above it starts getting a much more difficult! On shop fits I drill out 50 to 75mm holes in counters quite a lot with just an 18 volt cordless and a side handle (yes, I use the big drill, but in the past I used smaller ones) - ideally you want to drill half way through from one side, and the rest from the other, pulling the saw back regularly to clean-out the gullets between the teeth (which are pretty small). The carbide tipped hole saws with 2- to 4-teeth are actually better in that respect and clog less easily. One thing to note about hole saws is that the hole it cuts will not be clean-sided, so your inserts will need to have a flange or lip which covers the poor surfaces of the insides of the hole. TBH it doesn't matter that much so long as the inserts have flanges (most cable tidy inserts do)
    • Thanks Thanks x 1
  16. rsgaz
    rsgaz
    28 Jul 2014
    1,639
    Thanks Received:
    459
    Country:
    Here's a tip for that, you can massively speed up the time taken to drill a worktop with a holesaw.
    Just start the hole, maybe go 2mm deep.
    Using an auger (say, 12mm), drill all the way through, so that this 12mm hole slightly overlaps the groove made by the holesaw, like this...
    It gives the dust somewhere to go and then you can go all the way through in one go with the holesaw. Chipboard is very frustrating otherwise, it's not just the binding/clogging and having to keep stopping, but the resin in the chipboard begins to overheat and boil/burn!
    Gaz :)
    edit
    : but as said, once the arbor pokes out the bottom, drill upwards with the holesaw a little bit for a cleaner hole.
    • Thanks Thanks x 1
    • Like Like x 1
  17. OM2
    OM2
    18 Jan 2007
    638
    Thanks Received:
    Country:
    thanks guys.
    @rsgaz - oooh that's an awesome tip :)
    i'm a bit confused. what's better holesaw or Forstner drill bit?
Loading...
Share This Page
