But principally I was referring to the thread in general. As once again there is misunderstanding, misinformation and an OP reading what he wants.
Dan, I think it is actually you who have misunderstood this entire thread, and reading what
you want. You have been down on this right from the start and unwilling to listen and understand the point I was trying to make about personal usage. With some help from some previous posters it turns out my original hunch was right, and the boiler that I have been quoted is over sized for my personal use, that was the original point of the post. The point about GCV and NCV came after I learned from the discussion that net values were being advertised to make the boiler sound more impressive.
Your analogy about cars also doesn't make any sense. If you were charged for kWh at the petrol pump you might be able to stretch a connection, but you are charged by volume for fuel. Gas is charged in kWh and boilers heat output can be measured in kW so there is a direct connection. Within the UK market gas is charged in kWh based on the complete calorific value of the fuel. That's fair enough, but knowing that and then coming up with a calculation that ignores the part of the calorific value of the fuel on the input, so that they can then add it back in again at the output to make the boiler sound like it is more efficient than it really is, is dishonest. I'm not naive, I know that most marketing is dishonest and the company will use what it can to sell, but the UK government should be regulating these things and not allowing these claims.
Take for example my situation. I start with an Ideal Mexico, 73% efficiency. I am quoted for a 30kW boiler which is advertised as 99.5% efficient. With a little investigation I find out that that boiler, fitted into my existing system will only ever deliver close to 30kW of heat output if it is run at ~75deg. If I am going to set it at that temp then the efficiency drops to 88%, but that's a net figure. No values are published for gross, but if around 10% is recovered by the condenser then can I presume that the real, or the gross efficiency is ~78%. All of a sudden that paints a different picture in terms of ROI on the original boiler. To top it all off I find out last night that WB themselves only forecast a 10-15 year lifespan on their new boilers, and there are a lot of reports of boilers of all makes needing replaced in shorter time frames. I only pay around £600 a year for gas, if I reduced my bill by an optimistic 20% then on current prices I would pay back the cost of the new boiler in about 30 years!
Look, I am not complaining. This thread has been really, really useful for me and I have learned a lot, I appreciate the time everyone has taken to respond. I now know that the savings I would make are around 10% less than suggested by marketing. Considering this I might decide to let the boiler run for a bit longer until it starts to develop problems. When I do replace it I would go for the 24 kW boiler, and run it at lower temps to ensure that it is in condensing mode most of the time.
