What is more important when you decide on size of your combi boiler - radiator output or the flow rate?
Speaking to Worcester Bosch tech support, they are telling me that you shouldn't look at radiator output but 'how many taps you want to use at the same time'. And yet, there is plenty of recommendation in forums and energy saving websites that you need to choose as small a boiler as you can get away with based on radiator output. Our radiators would only need 15KW output so it seems daft to choose 30KW our plumber recommends. And yet, Worcester Bosch web quiz recommends same as the plumber. Further, on asking WB tech support, they tell me that WB boilers can modulate down and this does not affect efficiency of the boiler at all.
So, that would mean that only flow rates matter on modern boiler and I should choose one based on how many bathrooms I have and people liekly to be using them at the same time. Is that true?
