I am not in the slightest interested in what the nominal voltage is, and the question of whether it is 'right' or 'wrong' is plain silly - since it is essentially arbitrary, hence 'right' by a self-fulfilling definition.
What I do know is that safety-critical calculations should not be undertaken with nominal or 'average' values, but with the 'worst case scenarios' - which will be the minimum or maximum permitted supply voltages, depending upon what calculation is being undertaken. In the case of calculation of the maximum Zs of a circuit to achieve the required disconnection times by ADS, the minimum permissible supply voltage is the figure which should be used.
