images not showing
I'm glad that someone else is expreiencing that problem - if not only to prove that I don't make up my stories about it!images not showing
It's the same old problem of them being served via weserv.nl rather than direct from the source - quoting gets them from the source, but in the post they are from images.weserv.nlimages not showing
No, I haven't solved the problem - it persists, but it only happens occasionally, in certain circumstances (see flameport's post, but also see my response to him).Yes, me too. Just today. Yes, they are in 'quote'. Did you solve the problem when you had it, or did it just change on its own?
Interesting.It's the same old problem of them being served via weserv.nl rather than direct from the source - quoting gets them from the source, but in the post they are from images.weserv.nl ... Error from that is:
Error 410: Server couldn't parse the ?url= that you were looking for, because the hostname of the origin is unresolvable (DNS) or blocked by policy.
But why does this keep happening?It's the same old problem of them being served via weserv.nl rather than direct from the source - quoting gets them from the source, but in the post they are from images.weserv.nl
Error from that is:
Interesting.
This is the first time I've encountered the problem with something I've posted - it has previously only been with (occasional) things posted by others. However, those two images I posted earlier were inserted by doing a "Copy image" (not "Copy image address") from a website, followed by pasting into my post. I have always assumed (and, I suppose, still do!) that such a process does literally what it says on the tin - i.e. copies the actual image into my clipboard (without any knowledge of where it came from) and then literally pastes the image into my post. Are saying that when I do that, this site actually moves the image I've copied into my post to weserv.nl? However, even if that were the case, I don't really understand how it can get the image 'from the source' when it's quoted - since I don't see how it can know what the source is!
Could you perhaps help me understand?
KInd REgards, John
Is there really no alternative?
Or no option to make it work properly?
It breaks images which are http:... and not https:..., and it stops animated gifs from working.
What is the point of it, and how does it benefit us?
yes. i too can see the red sockets in the quote box, if i attempt to quote your other post,perhaps you'd like to try?
True. In terms of aesthetic fastidiousness, it would be ideal if they 'looked like' other plastic ones around (shape etc.), although I'll admit that there will not be in rooms/parts of the house where aesthetics are a major concern.
Again true, and I would probably consider that. However, if I removed 'the works' (if possible) and painted only the metal plate, those bits I hadn't painted would somewhat 'stand out' (if there were no pugs in them) - although I suppose that's fairly trivial. In other words, although not these colours, I would prefer something like ...
...rather than something like (without the USB gizmos)...
