Then you’ve failed to understand its proper usage.
PTFE tape acts as thread lubricant. This is highly desirable on any screwed compression fitting because it makes the torque applied to the nut relate more linearly to the compression on the mating surface.
I’m not a plumber. I’m an engineer.
Get some PTFE tape.
Engineers make me laugh. When I ran a shop, they were the bane of my life, but gave us something to laugh about.
My favourite was the one we nicknamed "Planman".
He phoned to ask me to fit a new pump. Told me the model. Fair enough. I always carried Grunnys in stick and said I would call to fit one. He started to give me the measurements. I said STOP - the new is a direct replacement.
Ten minutes later, the FAX (remember them ?
. ) kicked in and out spilled a perfect tech drawing of A PUMP. We had a laugh and chucked it in the bin, moaning about waste of toner.
Called to the job, Grunny in hand, he showed me to the boiler.
The tw@t had spent an age measuring and drawing but had failed to mention that it was fitted in a corner between a wall and the boiler, something like a Diplomat. You could hardly get a fag paper between the pump and the wall or boiler. Impossible to get tools in and pump out.
Funnily enough, I can't recall what I did.
The only thing dafter than an engineer is an engineers wife. They think they are married to a God
