Religion.
Pope work or Pipe work are but a slip of the finger apart.
Religion.
the Catholic Church is in enough trouble as it is!
But getting back on topic.
Sensing flow and return temperatures in and ajacent to the pump does allow for a system that can be fitted in the plant room and avoids the need to run a cable to a sensor at the furthest tapping point(s)
last place to put the only sensor on a system
Use the secondary return tapping you already have on the cylinder, a secondary return connection should not be below a third down the side of any hot water cylinder vented or unvented.As for Teeing into the cold feed, does that not waste a smidge of energy? I was lead to believe that returning the slightly cooler water towards the top of the tank would save energy rather than pitting that back into the bottom. Is this noticeable?
On the Joules tanknits got the outlet/inlet already there, should I make use of it or plumb it back into the cold feed with a swept T and a NR valve.
I am a little confused about the return pipe size.Why fill the return side with hot water ?
And think about this.....Could the return side be a much smaller diameter pipe. ? The return pipe only has to carry enough water to allow the flow side to become filled with hot water as far as the furthest tap. Once the flow side has hot water as far as the furthest tap the circulating pump can shut down until the water has cooled enough to require a bit more circulation.
Legionnaires
use 15 but the answer I got from grundfos was pipe should be no smaller than 20mm
could develop ( breed ) in any pipe that contains luke warm water. So it will develop in any hot water pipe that has been allowed to cool down because the tap at the end hasn't been used for a few hours. But it doesn't, the secret is in the word breed, if the hot water in the cylinder was hot enough to kill any bacteria then there can be no viable bacteria in the pipe work so hence no breeding can happen when the pipe work cools down
Twaddle as usual
