Hi just had the above fitted today through EDF, any hints or tips I should be aware of with it ?
Almost certainly a grant-funded installAs any pro here is likely to be an independent, you may have difficulty finding a lot of help, given that you chose a "big boy" for the paid work.
Just sayin'
If you've gone through that many of both heat exchangers i would suggest the issue is with your system and the quality of the water rather than the boiler itself.I hope that is one of the newer ideal boilers with the stainless steel heat exchanger, I'm on my third cast aluminium one in 10 years. I've also had 2 replacement secondary heat exchangers fitted due to jet engine like noise when running the hot water. I believe the new stainless ones are less problematic. Before the discussion comes up again no amount of arguing would convince Ideal that they should have lasted longer ( & they were bl**dy expensive to replace including their fees).
The last Ideal engineer that came told us the newer boilers had stainless heat exchangers & that the cast ones failing was not a problem with them, so I was just passing on that info.. Why do you say I was lucky that he did not take a water sample?Logic boilers don’t have stainless heat exchangers. And it sounds like you have been very lucky that the service engineer hadn’t taken a water sample.
No he didn’t. As I could go in and pick a brand new logic off the shelf and it would have s cast aluminium heat exchanger.The last Ideal engineered that came told us the newer boilers had stainless heat exchangers & that the cast ones failing was not a problem with them, so I was just passing on that info.. Why do you say I was lucky that he did not take a water sample?
