So I have an existing stand alone garage of cavity brick construction that needs a new roof and roof joists, currently the brickwork is about 1900mm high and as I'm putting a new roof on, i'd like to raise the overall height to 2500mm (it's on a boundary).
My plan is to build a stud wall about 400mm in height (+ 200mm for roof joists, OSB etc) to bring the finished height to 2500. I'll attach the new joists to the stud frame and the frame to the brick work, I could use advice on the best way to do this.
The brick work is 300mm thick - 2x 110mm brick plus 90mm cavity I guess (it's old).
My rough plan is to just replace the existing wall plate with a new one using resin anchors and attach the stud to this, am I missing anything?
Should I be using wall plate straps too?
Thanks in advance.
Thanks in advance.
