Does that necessarily work 'as expected' with hall-effect devices? I really don't know.You could put ten turns through the jaws to measure lower currents (and divide reading by ten).
I don't know enough about the theory and behaviour of hall-effect devices, but rsgaz's experiment seems to indicate that is does work 'as wexpected'.I don't know either but surely it must otherwise it would only work on single cores.
It's conceptually very similar but, as above, I would not know (on the b asis of my limited understanding of the theory) whether either would work 'as expected'.I.e. not multiple circuits in bunches - or is that different?
I have designed and currently sell test equipment which uses exactly that principle (with a Hall-effect device). You cannee change the laws of physics...Does that necessarily work 'as expected' with hall-effect devices? I really don't know.
Fair enough. As I said, I just didn't know enough about the theory behind, or behaviour of, hall-effect devices to be sure.I have designed and currently sell test equipment which uses exactly that principle (with a Hall-effect device). You cannee change the laws of physics...
Are you quoting those figures correctly? 19-24mA would be close enough to 21.5mA for most purposes, but you appear to be talking about 1.9-2.4mA - which certainly isn't!... But, when I swapped it for a 680Ω resistor, with the cheapo meter reading 21.5mA, that annoying fluctuating returned that I had mentioned before. Hopping around from 0.19 to 0.24 on the Uni-T display (times by 10 already, of course).
Ah, I think I now understand, and it doesn't look too bad at all.Yes. The bit in brackets was supposed to reduce confusion, but I think I may have caused some! ... I meant the Uni-T has, unbeknown to it, already multiplied the reading by 10. So it was fluctuating between 190 and 240mA. The reading would just not stop moving though. Every second it changed, the display was going... 0.19 → 0.22 → 0.20 → 0.24 → 0.19 → 0.23 → 0.21 → 0.24 → 0.19 → etc → etc (or something along those lines anyway).
