I’ve had to remove and replace tiles from the lower 3 or 4 feet of each of its 3 walls, due to damp damage from a cracked shower tray that went unnoticed by the previous owners for years, as far as I know. I’ve replaced the tray, and everything is bone dry, as the shower hasn’t been used since they discovered the crack years ago.
The left wall is structural, with some of the original tile adhesive remaining, so I’ve just stuck the tiles on again with some of the adhesive in the pic below, and they’re adhering very firmly, as you'd expect. The bottom 3 feet or so of the other two (stud) walls have had to be replaced with Moistsure Backer Board, and the tiles fixed to that with the same adhesive, about 3 days ago.
Today I find that none of the tiles on the backer board walls have stuck properly – they’re dropping off, so I just pulled them all off again. As you can see from the epics below, the tiles are covered with adhesive, stuck firmly – but virtually no adhesive has adhered to the backer board.
So the problem seems to be with the backer board. I somehow managed to miss the bit in the instructions which said I should seal it first with acrylic primer, so I’m going to do that – but do you think that’s definitely the problem, or have I done something else monumentally stupid?
I asked the guys at the builders’ yard, and they said they sold an awful lot of backer board, but the builders who bought it didn’t also buy primer.
Very very near the end of my tether with this project guys – any advice much appreciated
