Draining vaillant tank
4 Jan 2009
Herefordshire
Hi. Does anyone know how to drain one of these tanks please. It's leaking fron the immersion at the bottom thru my ceiling.
There should be a drain off on the cold feed in to the bottom of the cylinder unless the Installer could not be bothered.
All pipes are thru the top as unvented.
Found where it's leaking from.
The hot water outlet.
Got a plumber coming later in week to look.
Now I know the leak is at the top I won't drain Thank you
How much are these tanks to replace?
Old ones were like that.
Now get back to work :P
He want's to fit a tank with a built in expansion vessel thing.
And 3 port valve needs changing to 2x2port S system or current 3 port valve and a 2 port on HW (which comes with the tank)
