You cant fix anything to a gutter.
I would cut a U shaped sheet of ply [cut tight to chimney width] with ribs of timber secured to it, slip it round the back of the chimney and it will give non slip access to rear and sides, the front can be done with extended pole and roller from top of ladder.
Rubber stapled to underside would also help reduce any movement.
