Sympton: Radiators getting hot when only HW is selected and running.
OK so I realise the DV is messing about and not fully closing off the CH loop.
Purchase a DV repair kit, service the DV using all parts from the kit, 1st thing that wont fit is the gland that goes onto the bypass pipe, totally different size, so I replace it with the original, so far so good, then the HW connection leaks, new O ring fitted from kit, replaced with original O ring, no leak, sorted methinks.
HW and CH running fine, 2 days later leak from the spindle coming out of the DV manifold (baring in mind these are all new parts from the kit), strip down number 2 replace with original which restores the original problem.
So for my money as others have said service kits are not worth the trouble !
I am now going to get a replacement DV assembly and fit it before winter kicks in.
I can only assume the service kit I got was poor quality parts ! but I am not willing too go through the saga again !
