black alkathene pipe and concrete question
27 Jul 2006
I am about to fill in the hole in my kitchen floor, around the black alkathene pipe that is my main water input
Can anyone confirm if i can just concrete straight around it please, or is there any sort of tape wrap i should use to prevent any chemical reaction
TIA
So there's no need to put any tape or any ducting around the Alkathene pipe either ?
Tape or ducting is another question.
1. You don't need any tape.
2. If the alkathene is your incoming water main, it should be buried outside the property to a specific depth (more than 750mm, less than 1350mm from memory). Where it then comes inside the property it should be ducted and insulated in accordance with the water regulations.
3. If the part you are going to concrete around is within the thermal envelope of the building, you should be able to get away with doing nothing.
4. If there is a risk of it freezing, you ought to insulate it within a duct.
Thanks oldbuffer and yes it's purely filling the hole i made in the kitchen floor to give me room to move the pipe around so based on the info you have shared, i will just make good the hole with concrete
Thanks again ! (y)
Thanks again ! (y)
Can't hurt to wrap it in something if it gives you a bit of reassurance... Hessian lagging or cloth/duct tape would be good as anything (y)
I'd be inclined to use the foam pipe lagging, it will absorb any expansion or slight settlement, as well as giving heat insulation.
