That is 25 cu/metres per hour. It will give approx 258kW.What is the Maximum KW boiler will a U25 gas meter feed?
It does have an overload so it will do that.270kw give or take.
270kw give or take.
I think that translates to "haven't got a clue"They do not state the overload on badges. The overload is of a temporary nature, so running for years on end 50% continuously over the rated max volume is not on.
If only only you knew, which you do not. Stick to drains.I think that translates to "haven't got a clue"
A very poor effort of an explanation,absolutely incorrect,misleading and a gas safety issue.They do not state the overload on badges. The overload is of a temporary nature, so running for years on end 50% continuously over the rated max volume is not on.
Stick to drains
I fully agree with you. Those who do drains should stick to them, as they are essential, and not wander off into unknown territory messing things up.Nowt wrong with drains fella!
Just out of curiosity - what happens if it is is overloaded longterm? Does it wear out prematurely? It doesn't sound like thrashing an IC engine, or running an electric motor above rated load.The meter can cope with an overload for a short period, not continuous.
