Heating comes on with hotwater
17 Nov 2011
London
I have a Baxi Combi 80E boiler, the heating seems to come on now when I use the hot water even though the heating is switched off. What can be using this I have seen on youtube it could be the motorised valve/3 port valve, is this the diverter valve on the baxi? Can it be repaired or it is something that needs to be replaced?
Thanks in advance guys :)
baxi 80E is a combi boiler so wont have a motorised valve , it is the diverter valve inside the boiler that is faulty
Thanks so i can try repair it with a kit like "Diverter Valve Repair Kit 248061 248062"?
Do I need to service the DHW Pressure differential valve diaphragm, CH Pressure differential valve diaphragm and diverter valve operating head as shown in the pdf attached?
Thank you
Check the divertor actuator motor, it is common for water to pass throught the end seal and get into the motor, you will be able to see if this is the case , and if so drain the boiler change the front end seal and the motor
Thanks. Is there another name for this.. I can't find it in the service manual?
Thanks again
Ring Baxi and ask them. They will (hopefully) advise you of the various part numbers.
Diverter actuator motor is the diverter valve operating head... is that right?
sorry to bother you again ianmcd
Check the divertor actuator motor, it is common for water to pass through the end seal and get into the motor, you will be able to see if this is the case , and if so drain the boiler change the front end seal and the motor
if I put the hot water tap on running will I/where would I see the water passing through... I am unsure how I can tell is the water is passing through.
Great thank you and i guess if no there is no water in it, I need to get one of the Diverter Valve Repair Kits and replace all the diaphragms and seals contained in the kit?
Thanks again :)
you wont see the water passing, I have attached a pic of what you are looking for, pull the retaining clip out and see if water has got into the motor , it will be obvious if it has , make sure you turn the power off to the boiler first.
https://www.ebay.co.uk/itm/Baxi-Com...479964&hash=item41e344e2b2:g:p60AAOSw0O9bDAmZ
There is no Diverter actuator for my model.. i could not find it on my boiler... see attached. My boiler is combi 80e and not a combi instant 80e
  • 2.pdf
    2.pdf
I changed both the diaphragms on the DHW & central heating differential valve but i did not change anything. The central heating still comes on when the hot water is on, i.e. the central heating differential valve opens when i turn on the hot water.
I was not able to unscrew/take off the two parts circled in red on the pics to replace the bits inside, they were screwed on very tight. Anyone have any tips how to get them off so i replace the push rods and spring inside that parts?
Also anything else i need to check to see why the heating comes on when the hot water is switched on?
Thanks in advance
