My God Dannyboy is into bang, bangs. Amazing! Do you train spot as well?Time for bang bang:
And its still working? Even Ideal said it was crap. Time for new one soon.OK. My boiler is a (heat-only) Ideal minimiser SE50, coming uo to 20 years old, if anybody's interested.
You are really should not allowed in people's homes. After it being explained to this one by a few people repeatedly he still can't figure it out. This Shambolic one doesn't know the difference either. Sad isn't it. The thing is they actually do think the know. When put in their place the insults come. It shows a lack of education. These people have been trained, not educated. Sad, very sad.
You do not know the difference, along with the other buffoons, between a "zero governor" and a negative pressure gas valve. Fixit got it.Ideal use a zero governor
But he’s feckjng wrong FFS can you not see that.Navien clearly state on their vids that a 200,000 BTU boiler can use 24 foot of 1/2" pipe. They cannot understand what is happening. One says you need larger pipes bores. He wrote that. He did.
Do one thicko. It’s the same thing.You do not know the difference, along with the other buffoons, between a "zero governor" and a negative pressure gas valve. Fixit got it.
Looks like the inside of a Logic. Gas valve opens and fan sucks in right amount of gas and air mixes it in a Venturi then it’s forced into burner.
Still sh1te more friction created slowing gas down.As you have little idea, I will try to get you to think. The other one is a failure and not worth it. A 48 foot run of gas pipe to a boiler. The last 24 foot is 1/2" the first 24 foot 1". The negative pressure gas valve gets the gas to run down the 1/2" pipe faster. It does. Now, you never figured out what was happening.
He’s an erse better off ignored.Exactly, it’s a negative pressure gas valve. As fitted to ALL modern boilers
As you have little idea, I will try to get you to think. The other one, nwgs, is a failure and not worth it. A 48 foot run of gas pipe to a boiler. The last 24 foot is 1/2" the first 24 foot 1". The negative pressure gas valve gets the gas to run down the 1/2" pipe faster. It does. Now, you never figured out what was happening.
Still cannot figure it out can you?Still sh1te more friction created slowing gas down.
Have a look at the difference between pressure and flow. Try not blow yer mind
