Where does the wate pipe terminate?
You have a blocked pipe then try sulphuric acid and follow the instructions carefully.
Available from plumbers merchants. You will need Id if you don’t have an account.
Be careful!
WHY?Sorry Jeff.
DO NOT USE ANY ACID!
Andy
It terminates outside the house after about 3m of pipe - and is misconnected into the rainwater drain - so sulphuric acid down it would probably kill local wildlife.
A good scrub with a drain snake might do the trick?
Sulphuric acid is a unique chemical because it not only causes chemical burns, but also secondary thermal burns as a result of dehydration. This dangerous chemical is capable of corroding skin, paper, metals, and even stone in some cases. If sulfuric acid makes direct contact with the eyes, it can cause permanent blindness.
Apart from above it will also ruin a stainless sink.
Andy
Well if it's connected into the rainwater drain, that needs checking to see if this is permitted in your area.
As for the internal setup... Get those appliance hoses up higher and dropping down to the spigots; change the black 90° elbow (off the back of the trap) to 2 x 135° elbows with a bit of pipe in between, to create a large radius bend; and... there is what looks like overflow pipe connecting into the vertical section of black waste pipe at the back of the unit! I presume this is the condense from your boiler? Regardless, it is not a proper connection and the 20mm overflow will be protruding into the vertical pipe and creating a snag for waste material. If it is condense from boiler, there should be an air gap provision between it and the boiler. Get that connection and run checked out/changed.
