Hi all,
After a bit if advice if poss.
I have an old open vent system in my house, and from a fair old bit of investigation I definitely think the pump is in the wrong place. It's straight after the boiler on the flow side, before the open vent. From my workings it looks like it should be after the vent. However, my boiler is on the ground floor and the vent right up in the loft a fair old distance away. I've also noted that it seems the pump should be wired into the boiler for switching and power. This means to get the nesaserry configuration I think all new wiring would need running all the way from the boiler to the loft. This would mean a lot of destruction and redecorating. Unless by chance there is some where I could wire the pump to in the loft, however I'm not sure what is what with regards to wiring up there, there is a control box and the two valves and a fair bit of wiring.
Anyway, I was wondering if it's going to be a big pain to move the pump to the loft, what about just moving the pump to be on the boiler return pipe rather than the flow, could this be a better option.
The problems I'm seeing with the system is air in system, and just recently I've noticed I'm getting hot water pushed back into the feed/expansion tank. I can hear a glug every now and again, and the header tank water is a little warm if I dip my finger in.
Many thanks all
Many thanks all
